November 17, 1999, 05:51 |
Fluent-----questions.
Hi! I am using Fluent to solve a 3d problem of a centrifugal non-clogging impeller. The impeller sweeps thru' 360 degrees. I have a few questions regarding fluent. 1. I need to defin a pressure inlet and a pressure outlet. Is it possible to do this? Do I need to define a velocity also? 2. What is the Courant number? (Needed for Sliding mesh applications) 3. Because I will effectively have one circle rotating inside another I presume I do not need to worry about periodic boundary conditions? Any help for all or any of these questions would be much appreciated, Jack.
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Fluent general Questions | andygir | FLUENT | 0 | May 20, 2010 12:40 |
Fluent 6.3.26 vs 12.1 and partition method | Anorky | FLUENT | 0 | April 27, 2010 10:55 |
solving ocean wave with Fluent or CFX? | gholamghar | Main CFD Forum | 1 | March 21, 2009 12:49 |
Simple fluent questions | temp3733@gmail.com | FLUENT | 0 | May 18, 2005 12:50 |
