SIMPLE algorithm
Has someone been able to code an example of the SIMPLE algorithm in 2-D??
Im trying to create a code to calculate the flow of a gas in a packed bed using the SIMPLE algorith. The characteristc is that the are two inputs of gas; one on top and the other in the center. These inputs produce a mixing effect and therefore a 2-d flow field. When I apply the algorithm the pressure correction equations go unstable (im using Upwind discretisation). |
Re: SIMPLE algorithm
Is it laminar or turbulent? If turbulent, which model did you use?
It is a laminar flow, low reynolds within the packed bed
contack me, i have a simple code written in fortram ztdep@yahoo.com.cn
fortran code simple algorithm
hai dear
i need help to write simple code for 1d problem simple algorithm in versteeg book. nozzle problem.... do u have any code pls send me..... hareesh.aero@gmail.com |
simple algoritm
i am trying to write simple algoritm code in matlab.if you have this code help me or send to my email frae70@gmail.com
