SIMPLE help
Old   July 24, 2008, 07:42
Default SIMPLE help
Fernando Herrera
I need from someone that has applied the algorithm and understands it very well.
In this moment Im starting very small, at:
http://www.students.ncl.ac.uk/f.j.he...owexample.html
There is a small diagram of my actual process. It is the flow of a gas through a pipe. The black arrows are known velocities and the blue cells represent known pressures (in this case both are zero).
My solution procedure is this one:
1) First I assume a pressure distribution on the black cells as well as a velocity flow
2) Solve the momentum equations for the red arrows (horizontal and vertial) Six for the horizontal and 3 for the vertical velocities
3) With the new velocities calculate the pressure correction.
And here is where the problems start.
I don't know why, but when I solve the system of equations for the pressure corrections the results are unrealistic (negative pressures)
What would you do for the solution of this small system? What boundary conditions you would use? Is the system too small and therefore not well defined?
Old   August 10, 2008, 03:54
Default Re: SIMPLE help
Anishtain4
a system is not well defied for small sized just results are unrealistic. a negative pressure is not wrong, the equation give you the relative pressure field that you should correct it later. if you are using the staggered grid you should have 4 equation for the vertical solution. inflow is clear and just put a very low viscousity for the outflow cells as patankar mentiond it. it won't affect your solution. finally take a look ant 'patankar' or 'malalaskar' books they'll be good guid for you.
Thread Tools
Trackbacks are On
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? renyun0511 OpenFOAM Programming & Development 0 November 4, 2010 02:38
compressible SIMPLE method fakor Main CFD Forum 1 August 30, 2010 11:21
Making SIMPLE converge faster Fabio Main CFD Forum 4 April 9, 2006 11:35
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
