Boundary condition: intermediate velocity for fractional time step method
Like Tree1Likes
Old   June 19, 2015, 18:37
Default Boundary condition: intermediate velocity for fractional time step method
Rime
Rime is on a distinguished road
Hi!
How to calculate u*=u_n+1 for the intermediate velocity u*
Rime is offline   Reply With Quote
Old   June 20, 2015, 03:47
Filippo Maria Denaro
FMDenaro will become famous soon enoughFMDenaro will become famous soon enough
Originally Posted by Rime View Post
Hi!
are you talking about the intermediate BC.s in the fractional time step method? The literature is full of paper about this issue, starting from the hystorical paper of Kim & Moin on JCP you can find many many studies and proposals.
However, u_n+1 is the physical BC you have to know, a zero-order approximation simply set it as u*.
FMDenaro is online now   Reply With Quote
Old   June 20, 2015, 07:25
Rime
Thank u for the reply.
yes for fractional time step method
Old   June 20, 2015, 14:24
Rime
I use FSM with free pressure
boundary :
1)n.u*=n.u_n+1
u*=u_n+1
=> u*=u_n+dt*u_t
=u_n+dt*(-u*grad_u+(1/rho)*(mu*laplace(u)+grad_pression+F) is correct??
(depent to density rho)
2) t.u*=t.(u_n+1+(dt*grad_Phi)
3) for pressure:
laplace(phi)=(rho/dt)*div u^*
boundary n.grad_phi=0
4) and to calculate u_n+1
u_n+1=u*-(dt/rho)*grad_phi
No boundary conditions, ie I compute the velocity for interior and boundary points.
PS: I am beginner in CFD
I need your help
Thank you
Old   June 20, 2015, 18:27
I think your process need a careful revision...
1) Are you using a second order implicit time integration in the momentum equation?
2) The pressure equation is nothing else but the continuity equation in which the Hodge decomposition is substituded.
3) You need to take care of the product Div Grad, I suggest not to write it as Laplacian for a correct setting of the Neuman BC.s
4) What books/papers are you studying for the FTS method?
Old   June 20, 2015, 18:48
Rime
for time discretisation I use Adams Bashforth and Crank Nicolson scheme.
[1] Application of a Fractional-Step Method to Incompressible Navier-Stokes Equations
J. KIM AND P. MOIN
[2] David L. Brown, Ricardo Cortez,y and Michael L. Minionz Accurate Projection Methods for the Incompressible Navier–Stokes Equations
[3]J.L. Guermond, P. Minev c, Jie Shen An overview of projection methods for incompressible flows
and other paper for spatial discretisation (Radial basis function).
Old   June 21, 2015, 03:21
J. KIM AND P. MOIN
Ok, therefore you solve the implicit scheme for v* using the BC.s v* = v_n+1 + dt Grad phi_n, right?
Then you solve the elliptic equation Dic Grad phi_n+1 = Div q, wherein q is the source term.
What's wrong with your results?
Old   June 21, 2015, 07:01
Rime
Thank you for the reply.
my result diverge and when I use steady boundary I get a false solution.
Old   June 21, 2015, 07:10
check if you satisfy the continuity equation in each node just after the first time step.
Old   June 21, 2015, 07:16
Rime
I get div u around 0.04
Old   June 21, 2015, 07:29
you have some bug in the code, I think in setting the BC.s for the pressure equation.
Are you setting:
d phi/dn = (1/dt) ( v*-v_n+1).n
in the Poisson equation?
Old   June 21, 2015, 07:42
Rime
boundary :
u*=u_n+dt*u_t
n.u*=n.(u_n+1+(dt*grad_Phi)
for pressure:
So I use n.grad_phi=0
Old   June 21, 2015, 08:31
have you modified the source term in a consequent way?
Old   June 21, 2015, 08:36
Rime
sorry, I don't understand the question
Old   June 21, 2015, 08:43
the source term in the Poisson equation has been modified in a way congruent to the setting d phi/dn=0? How do you compute it?
Old   June 21, 2015, 09:19
Rime
div grad_phi = Div u^*
n.u^* = n.u_n+1 + n.grad_phi
so
n.grad_phi= n.(u^* - u_n+1^*)
I look that in my code I consider that the velocity in the boundary equal to zero (therefore that is false)
Old   June 21, 2015, 11:58
so
As you see, if you set in n.u^* = n.u_n+1 + n.grad_phi the BC.s :
n.grad_phi=0 ,
you MUST set also
n.u^* = n.u_n+1
therfore in computing the source term
Div u^*
you have to use the physical BC.s n.u_n+1.
One you have fulfilled such constraints, you have the compatibility condition satisfied and the Poisson equation will converge.
Finally, if you use a staggered secondo order discretization you should have the continuity equation satisfied up to machine precision
Rime likes this.
Old   June 21, 2015, 12:34
Rime
n.u^* = n.u_n+1
Div u^*
Thank you for your time, very useful.
n.u^* = n.u_n+1 <=> n.u^* = n.u_bc (bc=boundary condition)
because I can't see the difference between u_n+1 and steady u_bc
Old   June 21, 2015, 12:37
well, that's ok if the BC.s are steady. It must work
Old   June 21, 2015, 12:44
Rime
Thank you, I will try again.
I hope it works
Thread Tools
Trackbacks are On
Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Mesh Utilities 57 February 1, 2015 09:25
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
