Error in Axisymmetry BC
Old   August 4, 2008, 09:18
Default Error in Axisymmetry BC
Eduardo
Hello I am modeling a compressible flow. The system is a cylinder attached to a cylindrical pipe to it. The pipe allows water to come into the the cylinder and since the cylinder is full of water pressure is created as the water is pumped in. The Geometry is simple and the use if axisymmetry BC is justified. Inlet BC is mass-flow-rate set to 0.1 Kg/s The walls are set to constant temperature Axisymmetry BC the axis lies in X direction with the domain in the possitive Y direction.
Initialization: Upon initialization the initial values for velocity in x, y direction and temperature changed to 1.#QNAN.
Does anyone knows, had the same problem or know how to overcome this issue?
Kind regards
Eduardo
Axisymmetry problem and XFOIL JC Main CFD Forum 2 August 27, 2011 03:16
Initialization problem when using Axisymmetry BC Eduardo FLUENT 0 August 4, 2008 09:23
2D XY, Symmetry and Axisymmetry cases Gianfranco FLUENT 0 June 3, 2008 17:35
2D axisymmetry Vs non-axisymmetry geometry aPpA FLUENT 4 March 22, 2007 08:33
2d axisymmetry Cote CFX 7 January 12, 2007 10:41
