symetry B.C>
Old   August 6, 2008, 21:09
Default symetry B.C>
Shuo
Hi
I am simulating a free jet using Euler equations in the r-z plane. What are the boundary conditions for the symmetry plane and how do I implement it numerically?
Cheers Shuo
Old   August 6, 2008, 21:34
Default Re: symetry B.C>
Ahmed
No mass flow across the Z axis.
Old   August 6, 2008, 21:37
Shuo
what about the density and pressure?
Old   August 7, 2008, 00:47
Ahmed
No jumps, there is no mass crossing the symmetry plane, also be carefull, no mass crossing means the normal component of the velocity vector is equal to zero, but the parallel componet is not. you can check the Peric or the Versteeg & Malalasekra books for full details. Good Luck.
Old   August 7, 2008, 02:49
Praveen. C
If I understood correctly you are using cylindrical symmetry. Write the equations in r-z-theta coordinates and set all theta-derivatives and theta-velocity to zero. You will get an equation that looks almost like the 2-d equations but with some source terms.
Old   August 7, 2008, 09:58
jinwon park
It is similar to the rigid wall boundary condition.
Old   August 8, 2008, 00:48
Shuo
So its something like:
v_0 = 0
u_0 = u_1
P_0 = P_1
rho_0 = rho_1
where u & v are the velocity components in the z and r directions respectively. 0 is the symmetry boundary and 1 is the nearest node.
Shuo
Old   August 8, 2008, 00:50
jinwon park
In my case where flow is axi-symmetric, I set like that. The implementation of axi-symmetric flows is very straightforward. The results of my axi-symmetric cases were right compared to the analyric solution or experimental data. Good luck!
Thread Tools
Trackbacks are On
Confusion between 'non-slip' and 'slip' B.C jinwon park Main CFD Forum 7 March 6, 2008 05:56
how to set such B.C. in Fluent? Sherri FLUENT 1 January 12, 2006 13:32
Urgent! Help on UDF to set B.C. of 3rd type Ray Hong FLUENT 0 December 28, 2005 20:35
How to set B.C. of the 2nd or 3rd type in UDS? Ray Hong FLUENT 0 December 28, 2005 07:03
Non-Reflecting B.C. in NSC2KE Zou Chu Main CFD Forum 2 May 27, 1999 21:26
