Load Mesh file to C++
Old   August 6, 2008, 01:52
Default Load Mesh file to C++
ehsan
Hi How can i load Mesh file from Gambit to C++ ? with all Node,Element,Boundary !!!
Old   August 6, 2008, 12:58
Default Re: Load Mesh file to C++
Ahmed
save the mesh file in text format (in Gambit it is called nuetral format)
Old   August 8, 2008, 12:28
ehsan
I know that, but my problem is: how can i read that with C++?? with what operation,function & how ???
Old   August 11, 2008, 02:01
Markus Lummer
You can use the C++ input stream cin or the usual C-functions.
Old   August 11, 2008, 03:14
ehsan
can u explain it more ? i read it like this (C++): fstream infile("Grid.txt");
and after that i use two 'for' loop for X&y, but it didn't work !!!
Old   August 11, 2008, 03:18
Markus Lummer
Try
ifstream infile("Grid.txt");
infile >> x; infile >> y; // etc.
Old   August 15, 2008, 07:29
ehsan
i found it but iused with
FILE* f; f=fopen("filename"; scanf(f,"r");
it's read one line ...
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
