August 12, 2008, 08:39 |
Parallel computing with AVL FIRE
My system has core2quad CPU,and I have noted that during the run of the program FIRE 8.5 on win XP, just 25% of CPU (1 out of 4) is used. As I have found, To use all CPUs it needs Parallel processing capability. But this capability can not be used with win XP Operating System. Can Anyone help me please?
August 16, 2008, 12:47 |
Re: Parallel computing with AVL FIRE
Dear doki I myself use the AVL Fire V8.31 and the parallel processing can't be done on the multi core CPUs!
I don't know about the V8.5 and I can say that if you can do a batch job on the calculations then you can do the multi core to work . for example on the FEP projects the batch job will allow the multi core usage . by the way can you tell me if you can give me the V8.5 are you a licensed user or you have a cracked version . contact me via Email! |
Display Modes | |
unchangeable continuity residuals in parallel computing | wlt_1985 | FLUENT | 0 | August 1, 2011 12:15 |
AVL Fire transonic simulation | Ainil | Main CFD Forum | 1 | August 24, 2010 15:53 |
Diffusion equation solved using Parallel Computing | Sachin Paramane | Main CFD Forum | 0 | June 11, 2007 23:48 |
Parallel Computing | peter | Main CFD Forum | 7 | May 15, 2006 09:53 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
