-   -   HLL Riemann Shock Tube Matlab Problem (http://www.cfd-online.com/Forums/main/15640-hll-riemann-shock-tube-matlab-problem.html)
Luke F August 29, 2008 03:01
Hi There.
I am trying to write a simple code in MATLAB for an air-air shock tube using Godunov's method and the HLL Flux. I am using the ideal gas equation of state, and also assuming constant specific heats so we have P=RT*rho and e=(5/2)RT.
My present code is having problems and I think it may be me misunderstanding the Godunov/HLL Flux. Please, could someone look at my code and help me out. See below.
Thanks for the help
clear all
clc format long
%----------------Constants and Initial Conditions--------------------------
Dx=0.001; %Length of the Cells Dt=1*10^(-7); %Timestep N=1000; %Number of cells = 2N T=300; %Number of Timesteps R=287.05; %Specific Gas Constant for air
P_A=zeros(2*N,1); %Air Pressure of shock tube T_A=zeros(2*N,1); %Air Temperature of shock tube rho_A=zeros(2*N,1); %Air density of shock tube u_A=zeros(2*N,1); %Air velocity profile of shock tube c_A=zeros(2*N,1); %Air sound velocity profile of shock tube
Ta=20; %Atmospheric Temperature in Celcius Pa=101325; %Atmospheric Pressure in Pascals rho_a=(Pa)/(R*(Ta+273.15));%density of air (Ideal Gas Law)
u_a=0; %initial shock tube air velocity c_a=331.3*sqrt(1+Ta/273.15); %Air sound speed e_a=5/2*R*(Ta+273.15); %Air Internal Energy
PD=50000; % Pressure difference in the tube
%-----------Setting the initial condition in the tube----------------
for i=1:N
P_A(i)=Pa; T_A(i)=Ta; rho_A(i)=rho_a; u_A(i)=u_a; c_A(i)=c_a; P_A(N+i)=Pa-PD; T_A(N+i)=Ta; rho_A(N+i)=P_A(N+i)/(R*(T_A(N+1)+273.15)); u_A(N+i)=u_a; c_A(N+i)=c_a;
end
e_A=5/2.*R.*(T_A+273.15);
%----------------Creating initial set of conserved variables---------------
for j=1:2*N
Q_A(1,j)=rho_A(j); Q_A(2,j)=rho_A(j)*u_A(j); Q_A(3,j)=rho_A(j)*(e_A(j)+0.5*u_A(j)^2); end
Q_OLD=Q_A; AIRPRESSURE=P_A;
%--------------------HLL RIEMANN SOLVER----------------------------------
for timestep=1:T
time=T-timestep
Q_NEW(:,1)=Q_OLD(:,1);
Q_NEW(:,2*N)=Q_OLD(:,2*N);
for i=2:2*N-1
%--------------Calculating F(i+1/2)--------------------------
SL=min([u_A(i)-c_A(i),u_A(i+1)-c_A(i+1)]);
SR=max([u_A(i)+c_A(i),u_A(i+1)+c_A(i+1)]);
RHO_L=Q_A(1,i);
U_L=Q_A(2,i)/RHO_L;
E_L=Q_A(3,i)/RHO_L;
P_L=AIRPRESSURE(i);
RHO_R=Q_A(1,i+1);
U_R=Q_A(2,i+1)/RHO_R;
E_R=Q_A(3,i+1)/RHO_R;
P_R=AIRPRESSURE(i+1);
if SL>=0
F_A_PLUS=[RHO_L*U_L;RHO_L*U_L^2+P_L;U_L*RHO_L*E_L+U_L*P_L];
marker=1;
else if SR<=0
F_A_PLUS=[RHO_R*U_R;RHO_R*U_R^2+P_R;U_R*RHO_R*E_R+U_R*P_R];
marker=2;
else
F_A_PLUS=(SR.*[RHO_L.*U_L;RHO_L.*U_L.^2+P_L;RHO_L.*E_L.*U_L+U_L.* P_L]-SL.*[RHO_R.*U_R;RHO_R.*U_R.^2+P_R;RHO_R.*E_R.*U_R+U_R.* P_R]+SL.*SR.*([RHO_R;RHO_R.*U_R;RHO_R.*E_R]-[RHO_L;RHO_L.*U_L;RHO_L.*E_L]))./(SR-SL);
end
end
F(:,i)=F_A_PLUS;
end %end cell iteration
F(:,1)=F(:,2);
F(:,2*N)=F(:,2*N-1);
%----------------Updating Vector of Conserved Variables---------------
for i=2:2*N-1
Q_NEW(:,i)=Q_OLD(:,i)+(Dt/Dx).*(F(:,i-1)-F(:,i));
end
%------------------Updating Primitive variables-----------------------
rho_A=Q_NEW(1,:);
u_A=Q_NEW(2,:)./rho_A;
e_A=Q_NEW(3,:)./rho_A-0.5.*u_A.^2;
T_A=(2/5).*e_A./R-273.15;
c_a=331.3.*sqrt(1+Ta./273.15);
AIRPRESSURE=(2/5).*rho_A.*e_A;
clear Q_OLD
Q_OLD=Q_NEW;
clear Q_NEW
end %end timestep
Nishu July 7, 2009 13:44
I am looking into kind of similar problem.
Just wanted to know, were you able to crack out the problem?
Thanks
LUQILIN May 20, 2016 02:10
You should learn how to debug.
I suggest to give an linear initial condition to test your code. Then flux values at left and right of each interface should be same. Try to find out the errors.
I go through the code quickly. Maybe something is wrong with SL ans SR: use abs(u)-c and abs(u)+c instead.
