July 8, 2015, 09:43 |
Time scale and frequency of small eddies
Lucas
Rep Power: 10 |
Hello dear users,
I have the following problem: Air at standard conditions is flowing through a rectangular pipe. The needed data is: > Hydraulic diameter = 0,24 m > Flow speed = 30 m/s > Kintematic viscosity = approx. 2e-7 mē/s I now want to determine the time-scale and frequency of the smallest eddies, that occur in the flow. According to Kolmogorov's energy cascade the time scale of the smallest eddies is: ~ * With being the Time scale of the largest eddies (as an assumption I take / = 0,008 seconds). The Reynolds Number is calculated from the given hydraulic diameter, flow speed and viscosity - giving me a value of 27*10^6. This gives me a time scale of about 1,5*10^-6 seconds. Now I want to get the frequency which is 1/time scale and gives me 650 kHz. According to several sources in the literature (e.g.: Versteeg and Malalasekera) the frequency of those small eddies is in the range of 10 kHz for most engineering flows. I do see, that the assumption of taking the full amount of the mean velocity is not correct. Could anyone tell me which percentage (in this case the turbulence intensity) would be a good start? Any help or useful critic is highly appreciated! Last edited by Edeluc; July 8, 2015 at 11:38. |
July 8, 2015, 11:22 |
Filippo Maria Denaro
Rep Power: 71 |
you could also check in this way:
at the Kolmokorov scale Re_delta=O(1), therefore the reference velocity at the smallest scale is u = ni/delta. Thus 1/tau = ni/delta^2 and, for a known kinematic viscosity, you have just to estimate the spatial Kolmogorov scale. |
September 23, 2016, 09:13 |
thomas
Rep Power: 11 |
Hello Edeluc,
I know the post is old, but I am struggling with a similar problem. Did you solve yours? Thanks in advance. |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
hard to convergent with SU2 4.0 for Euler adjoint | Xianguu | SU2 | 1 | July 14, 2015 17:09 |
best setting for SU2 | mechy | SU2 | 3 | April 20, 2014 19:13 |
determination of time step in transient simulation | Guillaume Jolly | Main CFD Forum | 3 | April 9, 2007 20:13 |
