to simulate shock wave propagation with turbulence |
August 31, 2008, 03:54 |
hi
Can someone help me in describing the method to simulate shockwave with turbulence model (isotropy) thanks in advance |
August 31, 2008, 16:47 |
Re: to simulate shock wave propagation with turbul
I am not sure of the exact problems that you are considering and the mach number that you might encounter so consider this as a general idea.
1. For shock capturing you can use either ENO(WENO) or other similar shock capturing schemes. 2. For turbulence part you need to look into the pros and cons of using each turbulence model and the ability of the model to give meaningful results for the simulations that you are performing. |
Display Modes | |
Stationary Simulation of Shock Wave with Instationary Settings | matten | CFX | 3 | November 5, 2010 15:19 |
about local bump shock wave drag reduction | fxzf | Main CFD Forum | 5 | February 26, 2010 12:04 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
1D shock wave setup | ant | CFX | 7 | July 3, 2002 08:35 |
how to simulate wave? | dingding | CFX | 3 | July 18, 2001 11:20 |
