September 4, 2008, 15:35 |
axisymmetrical flow
Dear my friends
I want to validate my result in two dimentional laminar axisymmetrical flow.but my result show center velocity(umax) is 1.5 mean velocity(umax=1.5*umean).I read in fluid mechanic references in internal laminar flow in pipe that respect is 2 (umax=2*umean). could anyone tell me axisymmetrical flow's result is equal to intennal flow in pipe and what is correct result. best regards sara |
September 4, 2008, 16:32 |
Re: axisymmetrical flow
For a laminar pipe (assuming no variation in the circumferential direction) the max velocity is twice the average velocity. This result can be found in a closed form solution (see for example Fluid Mechanics by White).
September 5, 2008, 00:41 |
I want to know 2d axisymmetrical flow calculation's result is equal to 3d pipe flow result.help me many tanks
September 5, 2008, 08:46 |
If you are running a 2D axisymmetric laminar calculation, then the max velocity should be twice the mean. If you have fully 3D flow (with nonzero velocity components in all 3 directions) then the max velocity may not be twice the mean.
September 5, 2008, 09:42 |
dear my friend thanks for your paid attention for my case.could you calculate max velocity twice the mean. i can't .i calculate 1.5.
regards |
September 5, 2008, 15:02 |
I don't understand what you are asking for here - the classic laminar result is that the max velocity is twice the mean, whether I compute it or not. I don't have your code, so I have no way of determining where your error is. I would suggest that you first make sure that the velocity profile has a parabolic shape. If your velocity profile is correct, then the error may be where you compute the average velocity.
September 6, 2008, 08:11 |
dear my friend
my result show umax/umean=1.5.for this reason i am not sure result . my velocity profile is parabolic .if is possible send me your email then i send velocity profile for you . regards |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
