July 24, 2015, 03:52 |
Discharge coefficent (?)
matteo teone
Good morning, i am new to this forum.
I work for a company we do spare parts. I am talking about injectors for diesel engines. I shoud admit i don't have knoledge about CFD. American customer sent us a table of common rail nozzles (bosch type DLLA ecc...) One column of the table have a value "Cd" ... serching the web it shoud be "discharge coefficent" I tried to understand what it is but I am not able. I send 3 lines from the table: INJ. NOZZLE HOLES SPRAY HOLE DIAMETER FLOW Cd *** ****** 7 0.195 1814 0.94 *** ****** 7 0.198 1879 0.94 *** ****** 7 0.163 1211 0.9 Flow is 100bar pressure value is in ml/min HANY HELP WELLCOME |
July 24, 2015, 04:11 |
shahrooz
Rep Power: 14 |
I guess it is not related to CFD, is it?
July 24, 2015, 05:45 |
Lucas
Rep Power: 10 |
shahrooz is right - At the moment the question is not related to CFD.
Anyways - The discharge coefficient is a ratio of the actual mass flow of the injector and the ideal mass flow. Cd = actual mass flow / ideal mass flow The actual mass flow is determined in experiments (e.g.: with a "Bosch Tube"). The ideal mass flow is the maximum amount of mass that can pass through the nozzle per time and related to the nozzle diameter, number of nozzles, nozzle type, fuel, and many more. A very simple way to calculate the ideal mass flow is using Bernoulli's law. By restating the equation you get the following: Ideal mass flow = n * A * n ... Number of nozzle holes A ... Hole surface area ... Fuel density ... Injection pressure ... Back pressure Your values of Cd ~ 0.9 point out that it is a very new nozzle, because Cd is close to 1. The more use of the nozzle, the smaller Cd (due to depositions in the holes decreasing the actual mass flow). Last edited by Edeluc; July 24, 2015 at 09:21. |
July 24, 2015, 10:06 |
matteo teone
Thankyou very mutch.
But why you are telling me this question is not related to CFD? CFD softwares are not made for this type of works, calculations? |
July 24, 2015, 14:45 |
#5 | |
shahrooz
Rep Power: 14 |
I didn't know the answer of your question but wanted to inform you this is not CFD related so you could ask it somewhere else that has a higher chance **of getting an answer. Last edited by shahrooz.omd; July 25, 2015 at 08:50. |
Display Modes | |
numerical oscillation when using H-curve to represent discharge through turbine | efdc | Main CFD Forum | 0 | November 18, 2013 10:09 |
Need ideas-fuel discharge system | Jan | FLUENT | 1 | October 10, 2006 23:05 |
Need ideas-fuel discharge system | Jan | CFX | 1 | October 9, 2006 08:16 |
need ideas-fuel discharge system | Jan | Siemens | 0 | October 9, 2006 04:31 |
Need ideas-fuel discharge system | Jan | Main CFD Forum | 0 | October 9, 2006 04:27 |
