How to run the 2D Euler equation code
Old   September 15, 2008, 08:26
Default How to run the 2D Euler equation code
Khanh
I am currently studying the book: Computational Fluid Dynamics: Principle and Application, by J.Blazek.
I would like to know the ways to run the code: "struct2D" given in the CD attached with the book.
I have opened a project, then add all the file in "src" into the project.
When it is compiled and built, there is no error.
When it is run, it appears only the phrase: "SOLUTION OF 2-D EULER/NAVIER-STOKES EQUATIONS ON STRUCTURED GRIDS, J. Blazek, Version 1.5 from Dec" on the command windows. The execution suspend from this event.
I didn't see any selection for inputing the parameters later on.
Please give me a help Thank you in advance
Old   September 30, 2008, 12:53
Default Re: How to run the 2D Euler equation code
A.S.
Can you provide me the codes, I can have a look and advice you on it. If your can provide me the airfoil and cascade grid generator it will be nice.
Thanks
Apurva
Old   November 3, 2011, 05:32
Default I have the same problem as you do
Guo Qinghua
gchnhn is on a distinguished road
but it's not the program's fault
look into the code, you will know that it's waitting for you entering some control parameters and file names
gchnhn is offline   Reply With Quote
Thread Tools
Trackbacks are On
writing an acoustic code based on FW-H equation, have a question regarding pressure mrshb4 OpenFOAM Running, Solving & CFD 3 November 8, 2014 21:12
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Jacobian of 1D Euler Equation of Gas Dynamics Simplicity. Main CFD Forum 3 September 6, 2011 14:12
2d Jameson Euler code Dayton Main CFD Forum 5 January 17, 2011 14:18
Convert Euler code to full N-S Soren Main CFD Forum 3 June 25, 2002 04:47
