from sticking coefficient to preexponential factor
Old   September 18, 2008, 08:05
Default from sticking coefficient to preexponential factor
Bache
Hi everyone
I'm interested her in converting a sticking coefficient to a preexponential factor in chemkin.
In fact I want to use Comsol to model a kinetic scheme validated in Chemkin, and Comsol doesn't manage sticking coefficients or surface species.
I tried the formula given by the chemkin theory, but I didn't get the same results (with chemkin you can use both), unless multiplicating arbitrarly by 100 the value calculated...
I explain: considering the adsorption of NO: NO(g) + * -> NO(ads)
r(mol/cm2/s) =k cNO(mol/cm3) cv(mol/cm2) considering this equation k must be in cm3/mol/s and you can't get this by the equation: k=S/(SurfConc (mol/cm2))* (RT/(2Pi*M(kg/mol))
Has someone already solved this problem?
Thread Tools
Trackbacks are On
What's the influencing factor of slipping coefficient? jimzhou Main CFD Forum 2 February 10, 2011 22:49
Sticking Coefficient Problem ohm121 FLUENT 0 April 25, 2010 10:23
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Sticking Coefficient Razvan FLUENT 0 December 2, 2005 10:41
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
