September 28, 2008, 01:43 |
codes for water hammer on pipe flow
hi all,
i am new to fortran. i need to write program for pipe flow with water hammer effect. assume a model consists of reservior with one pump sucks the water from the reservior. a check valve is installed ahead of the pump. And the water is circulated, when the pump trips the pressure transients will occur. Can any one give the idea of how to strat write the codes( in fortran or matlab) by using finite differnce method. thanks in advance for ur reply. |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
Turbulence intensity in fully devloped pipe flow - Reference | Shocktrain | Main CFD Forum | 0 | October 14, 2010 06:58 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
