Convergence problem with Spalart-Allmaras Turbulence Model using mass flow at exit
Old   September 4, 2015, 05:25
Default Convergence problem with Spalart-Allmaras Turbulence Model using mass flow at exit
sagar
sagarparikh31 is on a distinguished road
Hello All,
I am simulating 2 stage fan, and I am using Spalart-Allmaras (SA) turbulance model. Initially I started with giving outlet boundary condition as average static pressure and it got converged within 350 iterations (Steady State), also results are matching the experimental values.
From this result I got the value of mass flow rate at outlet boundary (where I had applied average static pressure) and then tried to simulate the same model by using mass flow rate value rather than average static pressure. But then the results are not converging even after 1500 iterations.
Does anyone having any idea for this kind of problem using SA turbulence model?
sagarparikh31 is offline   Reply With Quote
Low Mach number wing/body junction convergence Zen SU2 6 May 3, 2019 04:51
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
Numerical integration of Spalart Allmaras turbulence model RenardP Main CFD Forum 0 June 11, 2009 14:53
