-   -   using UDF in Fluent for unsteady cavitation (http://www.cfd-online.com/Forums/main/15911-using-udf-fluent-unsteady-cavitation.html)
Pejman October 22, 2008 11:11
I am working on 3D cavitation modeling of a hydrofil using Fluent 6.2.16 . The problem I have countered is that the k-epsilon RNG model itself can not simulate the unsteady behavior of cavitation. It just simulate the inception of the cavities. And then the flow becomes steady withoud any Re-entrant jet or cloud cavitation separation.
To solve this problem, I have to define a UDF that correct this problem by this way:
μt=f(ρ)*Cμ*k^2/ε
f(ρ)=ρv+((ρm ' ρv)^10)/((ρl ' ρv)^9)
Can anybody help me to define a UDF for it? Actually I don't know anything about UDF's in Fluent. Just give me a hint or tell me the works I have to do.
Thanks
Pejman
Pejman October 22, 2008 11:13
Re: using UDF in Fluent for unsteady cavitation
By the way I have seen this solution in 2 papers but they have not described anything else!
mettler October 22, 2008 11:22
from what I can remember, you have to convert that into a C+(?) code..compile it etc. Then, within Fluent you call it up. You have to make sure that you pass the correct variables thru.
Pejman October 22, 2008 16:16
Thanks Mettler for your information. Do I have to identify the variables or the software recognize them already?
mettler October 22, 2008 16:22
I would imagine you are going to have to identify them the same way Fluent does..
sandy October 23, 2008 07:27
The following link might help you http://www.fluentusers.com/fluent/do.../udf/node3.htm
Pejman November 6, 2008 11:18
Thanks Sandy, but I can not use it, since I can not register!
