Any comment on SAMM?
Old   November 23, 1999, 14:28
Default Any comment on SAMM?
Quazi
I would appreciate any feedback from SAMM (Semi Automatic Meshing Methodology) users as far as how good is it in generating predominantly hexahedral mesh with minimum user interaction.
Thanks in advance.
Old   November 24, 1999, 14:21
Default Re: Any comment on SAMM?
Joern Beilke
Just tell us what you want to do with SAMM !
It works very good for some applications and not so good for other ones. It s not a tool with a "solve-my-problem" button.
Old   November 26, 1999, 09:07
Juergen Sitta
I would say, with increasing complexity of your problems, you will see your chance to solve your problem with SAMM decreasing to nil!
Old   November 30, 1999, 09:50
Paul Hancock
The first year I had SAMM was a waste. There were just too many un-resolved cells to make it useful. However, over the last two years, Wayne has worked very hard to reduce the amount of semi in the Semi-Automatic-Meshing-Methodology. And it has become my mesher of choice.
If your CAD data is of high quality and your geometry does not change scale very much ( you don't have big things next to very small things - although local refinements should relax this problem) SAMM will work well.
Everyone knows that there is NO magic Mesh button - Right???
Old   December 2, 1999, 17:29
Tom
I totally agree to Paul. Today, samm can be a very powerful tool for meshing, even for complex geometries. The problem is: one has to know how to use samm effectively.
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 09:04
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
give your comment for this problem rt Main CFD Forum 2 August 3, 2006 00:03
SAMM users Bart Prast Siemens 1 August 24, 2000 04:34
SAMM meshing D Redinger Siemens 1 January 1, 2000 10:56
