October 27, 2008, 21:34 |
LES Test Filtering
Hi All; I am working on Dynamics model. I need to filter the variables to have L_ij and M_ij. In M_ij we need to filter S_ij (test filtering). There exist two ways to filter S_ij. One is to calculate S_ij from the calculated velocities, and then use Simpson or trapezoidal rule to filter it. The second way is to filter the velocities and calculate the filtered S_ij from the filtered velocities.
S_ij = (uf_i/x_j+uf_j/x_i)/2 -- ---- uf is the double filtered velocity. And also same for |S|. It is possible to calculate |S| and then filter, or filter S_ij and calculate the filtered |S| from the filtered S_ij. Can you please guide me, which one is correct? Thank you in advance. |
calculation of test filter quantites for desired parameters(equations) in les | mrn | FLUENT | 0 | July 15, 2010 05:04 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
LES test filtering | keith | Main CFD Forum | 4 | October 14, 2008 17:05 |
