LES Test Filtering
Old   October 27, 2008, 21:34
Default LES Test Filtering
Nabi
Hi All; I am working on Dynamics model. I need to filter the variables to have L_ij and M_ij. In M_ij we need to filter S_ij (test filtering). There exist two ways to filter S_ij. One is to calculate S_ij from the calculated velocities, and then use Simpson or trapezoidal rule to filter it. The second way is to filter the velocities and calculate the filtered S_ij from the filtered velocities.
S_ij = (uf_i/x_j+uf_j/x_i)/2 -- ---- uf is the double filtered velocity.
And also same for |S|. It is possible to calculate |S| and then filter, or filter S_ij and calculate the filtered |S| from the filtered S_ij. Can you please guide me, which one is correct? Thank you in advance.
calculation of test filter quantites for desired parameters(equations) in les mrn FLUENT 0 July 15, 2010 05:04
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
LES test filtering keith Main CFD Forum 4 October 14, 2008 17:05
