A algorithm problem meets in the FTC3D code
1 Attachment(s)
Hi all,
Recently,I download the FTC(Front-Tracking code)3D code from the internet. But the FTC3D had been modified already. Specially, I think the subroutine about updating the density field is not exact. Then I found the FTC2D code from Dr. Tryggvason's personal web:http://www3.nd.edu/~gtryggva/. And I rewrite the subroutine of the FTC3D record to the algorithm of the FTC2D, but I meet a problem! The subroutine in the FTC2D is: subroutine dens2(r,rtmp,tmp1,tmp2,nxp2,nyp2,iii,idim,pt,ptcon ,icp,elcon, elprop,maxpt,maxel) dimension tmp1(nxp2+2,nyp2+2), tmp2(nxp2+2,nyp2+2) dimension rtmp(nxp2,nyp2) dimension r(nxp2,nyp2) dimension iii(idim,2) dimension pt(maxpt,2), ptcon(maxpt) dimension icp(maxel,2),elcon(maxel),elprop(maxel,3) integer ptcon,elcon,np,ffp,lfp,fep, ne,ffe,lfe,fee common/grid/hxi,hyi,nxp1,nyp1,nx,ny,xl,yl common/bounds/ibdry,jbdry,nxlast,nylast common/front/np,ffp,lfp,fep, ne,ffe,lfe,fee,amax,amin common/fparam/xmv,mv,fxl,fyl common/flprop/r1,r2,m1,m2,gx,gy,rro xx=(xmv+0.5)*xl yy=(xmv+0.5)*yl c generate gradient vector sc=1./2. pi=4.*ATAN(1.) pd2=0.5*pi cnstx=(.25*hxi)**2 cnsty=(.25*hyi)**2 do 10 i=1,nxp2+2 do 10 j=1,nyp2+2 tmp1(i,j)=0.0 tmp2(i,j)=0.0 10 continue k=ffe do 30 ll=1,ne p0x=pt(icp(k,1),1) p0y=pt(icp(k,1),2) p1x= p0x+amod((pt(icp(k,2),1)-p0x+xx),xl)-0.5*xl p1y= p0y+amod((pt(icp(k,2),2)-p0y+yy),yl)-0.5*yl xc=0.5*(p1x+p0x) yc=0.5*(p1y+p0y) x1=p1x-p0x y1=p1y-p0y c calculate components of n.dA rx=-y1 *elprop(k,1) ry= x1 *elprop(k,1) c generate a grid value xt=amod((xc+0.5/hxi)+xmv*xl,xl) yt=amod((yc+0.5/hyi)+xmv*yl,yl) ir=1+int(nx*xt/xl) jr=1+int(ny*yt/yl) do 40 i1=1,4 do 40 j1=1,4 ii=ir-2+i1 jj=jr-2+j1 drx = 1. + cos((xt*hxi - float(ii-1))*pd2) dry = 1. + cos((yt*hyi - float(jj-1))*pd2) tmp1(ii+1,jj+1)=tmp1(ii+1,jj+1)+rx*drx*dry*cnstx tmp2(ii+1,jj+1)=tmp2(ii+1,jj+1)+ry*drx*dry*cnsty 40 continue k=elcon(k) 30 continue c correct boundaries: call gbd1(tmp1,tmp2,ibdry,jbdry,nxp2,nyp2) do 900 i=1,nxp2 do 900 j=1,nyp2 900 rtmp(i,j)=0.0 do 80 i=2,nxp1 do 80 j=2,nyp1 rtmp(i,j)= 0.5*(hxi*(tmp1(i+1+1,j+1)-tmp1(i-1+1,j+1))+ 1 hyi*(tmp2(i+1,j+1+1)-tmp2(i+1,j-1+1))) 80 continue c set connection node=0 do 100 i=2,nxp1 do 100 j=2,nyp1 cc=0.0 do 105 io=1,3 do 105 jo=1,3 105 cc=cc+rtmp(i+io-2,j+jo-2) if(abs(cc) .gt. 1.0e-03)then node=node+1 iii(node,1)=i iii(node,2)=j end if c open(13,file='cc',status='new') c write(13,*) cc,i,j,node 100 continue c pause numnd=node c then iterate c-----------the following should be read in itmax=1000 bet=1.2 errmax=1.0e-05 c------------------------------------------ cf=0.5/(hxi*hxi+hyi*hyi) do 200 iter=1,itmax err=0.0 do 210 node=1,numnd i=iii(node,1) j=iii(node,2) c do 210 i=2,nxp1 c do 210 j=2,nyp1 rold=r(i,j) r(i,j)=(1.0-bet)*r(i,j)+bet*cf* 1 (hxi*hxi*(r(i+1,j)+r(i-1,j))+ 2 hyi*hyi*(r(i,j+1)+r(i,j-1))-rtmp(i,j)) err=err+abs(rold-r(i,j)) 210 continue c set boundary terms... if(ibdry .eq. 0)then do 110 j=1,nyp2 r(nxp2,j)=r(2,j) r(1,j)=r(nxp1,j) 110 continue else do 115 j=1,nyp2 r(nxp2,j)=r(nxp1,j) r(1,j)=r(2,j) 115 continue end if if(jbdry .eq. 0)then do 120 i=1,nxp2 r(i,nyp2)=r(i,2) r(i,1)=r(i,nyp1) 120 continue else do 125 i=1,nxp2 r(i,nyp2)=r(i,nyp1) r(i,1)=r(i,2) 125 continue end if c check convergence...... if(err.lt.(errmax*float(numnd)))go to 300 200 continue 300 continue write(*,*)' DENSITY: ',err,' after ',iter,' iterations', 1 ' using ',numnd,' nodes' return end And I rewrite the 3D subroutine: subroutine creater(r,rtmp,tmp1,tmp2,tmp3,nxp2,nyp2,nzp2,iii,i dim,pt,ptcon, icp,elcon,maxpt,maxel) dimension tmp1(nxp2,nyp2,nzp2),tmp2(nxp2,nyp2,nzp2) dimension tmp3(nxp2,nyp2,nzp2),rtmp(nxp2,nyp2,nzp2) dimension r(nxp2,nyp2,nzp2) dimension iii(idim,3) dimension pt(maxpt,3), ptcon(maxpt) dimension icp(maxel,3),elcon(maxel) dimension work(10000),bd(1,1) integer ptcon,elcon,np,ffp,lfp,fep, ne,ffe,lfe,fee integer p1,p2,p3 common/grid/hxi,hyi,hzi,nxp1,nyp1,nzp1,nx,ny,nz,xl,yl,zl common/front/np,ffp,lfp,fep, ne,ffe,lfe,fee,amax,amin,aspmax common/flprop/r1,r2,m1,m2,gx,gy,gz,st,rro c generate gradient vector sc=1./3. pd2=0.5*pimach(1.0) cnstx=(.25*hxi)**3 cnsty=(.25*hyi)**3 cnstz=(.25*hzi)**3 dxh=0.5/hxi dyh=0.5/hyi dzh=0.5/hzi do 10 i=1,nxp2 do 10 j=1,nyp2 do 10 k=1,nzp2 tmp1(i,j,k)=0.0 tmp2(i,j,k)=0.0 tmp3(i,j,k)=0.0 10 continue k=ffe do 30 ll=1,ne p1=icp(k,1) p2=icp(k,2) p3=icp(k,3) xc=(pt(p1,1)+pt(p2,1)+pt(p3,1))*sc yc=(pt(p1,2)+pt(p2,2)+pt(p3,2))*sc zc=(pt(p1,3)+pt(p2,3)+pt(p3,3))*sc x1=pt(p2,1)-pt(p1,1) y1=pt(p2,2)-pt(p1,2) z1=pt(p2,3)-pt(p1,3) x2=pt(p3,1)-pt(p1,1) y2=pt(p3,2)-pt(p1,2) z2=pt(p3,3)-pt(p1,3) c calculate components of n.dA rx=(y1*z2-y2*z1) ry=(z1*x2-z2*x1) rz=(x1*y2-x2*y1) c generate a grid value xt=amod((xc+dxh)+5.0*xl,xl) yt=amod((yc+dyh)+5.0*yl,yl) zt=amod((zc+dzh)+5.0*zl,zl) ir=1+int(nx*xt/xl) jr=1+int(ny*yt/yl) kr=1+int(nz*zt/zl) do 40 i1=1,4 do 40 j1=1,4 do 40 k1=1,4 ii=ir-2+i1 jj=jr-2+j1 kk=kr-2+k1 drx = 1. + cos((xt*hxi - float(ii-1))*pd2) dry = 1. + cos((yt*hyi - float(jj-1))*pd2) drz = 1. + cos((zt*hzi - float(kk-1))*pd2) ii=mod((ii-1+5*nx),nx)+1 jj=mod((jj-1+5*ny),ny)+1 kk=mod((kk-1+5*nz),nz)+1 tmp1(ii,jj,kk)=tmp1(ii,jj,kk)+rx*drx*dry*drz*cnstx tmp2(ii,jj,kk)=tmp2(ii,jj,kk)+ry*drx*dry*drz*cnsty tmp3(ii,jj,kk)=tmp3(ii,jj,kk)+rz*drx*dry*drz*cnstz 40 continue k=elcon(k) 30 continue c correct the ends of the box call gbdry2(tmp1,nxp2,nyp2,nzp2) call gbdry2(tmp2,nxp2,nyp2,nzp2) call gbdry2(tmp3,nxp2,nyp2,nzp2) do 900 i=1,nxp2 do 900 j=1,nyp2 do 900 k=1,nzp2 rtmp(i,j,k)=0.0 900 continue do 80 i=2,nxp1 do 80 j=2,nyp1 do 80 k=2,nzp1 rtmp(i,j,k)=0.5*(hxi*hxi*(tmp1(i+1,j,k)-tmp1(i-1,j,k))+ 1 hyi*hyi*(tmp2(i,j+1,k)-tmp2(i,j-1,k))+ 2 hzi*hzi*(tmp3(i,j,k+1)-tmp3(i,j,k-1))) 80 continue node=0 do 100 i=2,nxp1 do 100 j=2,nyp1 do 100 k=2,nzp1 cc=0.0 do 105 io=1,3 do 105 jo=1,3 do 105 ko=1,3 cc=cc+rtmp(i+io-2,j+jo-2,k+ko-2) 105 continue if(abs(cc) .gt. 1.0e-3)then node=node+1 iii(node,1)=i iii(node,2)=j iii(node,3)=k end if 100 continue numnd=node itmax=1000 errmax=1.0e-3 beta=1.2 cf1=0.5/(hxi*hxi*hxi+hyi*hyi*hyi+hzi*hzi*hzi) do 200 iter=1,itmax err1=0.0 do 210 node=1,numnd i=iii(node,1) j=iii(node,2) k=iii(node,3) rold=r(i,j,k) r(i,j,k)=(1.0-beta)*r(i,j,k)+beta*cf1* 1 (hxi*hxi*hxi*(r(i+1,j,k)+r(i-1,j,k))+ 2 hyi*hyi*hyi*(r(i,j+1,k)+r(i,j-1,k))+ 3 hzi*hzi*hzi*(r(i,j,k+1)+r(i,j,k-1))-rtmp(i,j,k)) err1=err1+abs(rold-r(i,j,k)) 210 continue call gbdry(r,nxp2,nyp2,nzp2) if(err1.lt.errmax) go to 300 200 continue 300 continue write(*,*)' DENSITY: ',err1,' after ',iter,' iterations', 1 ' using ',numnd,' nodes' return end The results of the 2D and 3D code are in the attachment. I readed the article of Dr.Tryggvason "A Front-Tracking Method for the Computations of Multiphase Flow'', the section 3.5 "Updating the Material Properties" explain the algorithm of Updating the density field. But I can't understand. So I need some help to modify the code. Thanks! Yours' Liaobin |
