basics in cfd
Old   November 22, 1999, 16:17
Default basics in cfd
tonshal
Hello I have worked in experimental automotive cooling system component analysis. I wanted to know about the books, which will give some basics in CFD. I am reading, CFD basics and application by Jr. Anderson. From my reading I think the book deals with finite difference method. I don't know if I should continue with this are any other book, which deals CFD from finite volume point of view.
Any help will be greatly appreciated
Tonshal
Old   November 22, 1999, 17:39
Default Recirculationg zones Vs. Thin Layer N.S.
Mohammad Kermani
Hi dear scholars:
I am running a Compressible Thin Layer N.S. code for the the flow in Backward facing step. THis flow contains reciculationg zones. And my questions are:
1) are the governing equations, i.e. TLNS, valid for this geometry. If not, any clue how much should i expect my results to be off. suppose the flow is laminar flow, say Re=400 (Armaly 1983)
2) And more importantly, if the TLNS is not valid in reciculationg zones, then why people are using TNLS for the Shock boundary layer interaction or compression corners which both of them contain flow separeation.
I thank you for your contributions.
Old   November 23, 1999, 17:05
Default Re: basics in cfd
mahesh prakash
Have you heard about the book by the finite volumes guru S. V. Patankar? It is called Numerical Heat Transfer and Fluid Flow and is published by Hemisphere Publishing. I would highly recommend you to read this book.
Cheers
Old   November 25, 1999, 12:41
J. Y. Luo
A very good book on finite-volume based CFD:
Computational Methods for Fluid Dynamics by Joel Ferziger, Milovan Peric / Published 1996 or 1999
(you should be able to find it in http://www.amazon.com)
Old   November 25, 1999, 22:37
John Chien
(1) CFD is a very broad field. Any time when a computer is used to simulate the flow problem, it is part of CFD. (2). If you have not written a CFD code before, it is useful to read as many books as possible. And from these books, you will be able to get a general feeling and an overall picture. (3). The ideal way to learn is to have somebody to teach you how to write a CFD code. This will save a lot of time. (4). Books of CFD normally have very little details in it. The best place to start is to read " numerical methods for applications, or for engineers" types of books, especially the one with a lot of Fortran language programs in it. Normally, these numerical methods books cover the very basic, through the ordinary differential equations, and the partial differential equations. (5). CFD in general deals with the numerical solutions of the partial differential equations. And the finite difference method is the formal approach. But one can easily show that using the finite volume approach, the resultant algebraic equations are the same as those obtained from the finite difference method on rectangular mesh. So, at that level, there is no difference. (6). You can also read the PhD dissertation on the CFD solutions, especially the one with code listing attached in the dissertation. This will give you the first hand information about the CFD code development. (Books and dissertation information can be easily obtained from a library ) (7). It is really nice to know that there is a person who is interested in reading.
Old   November 29, 1999, 07:59
Sanjeev Kumar
Dear Mr.John I hace also the same problem and i highly appreciate your advises. Can you please give me some insight into hypersonic nonequilibrium flow and any text book on this?
with regards
---Sanjeev Kumar
Old   November 29, 1999, 21:55
John C. Chien
(1). You need to read books on: thermodynamics, statistical thermodynamics, kinetic theory of gases, physical gasdynamics, inviscid hypersonic flows, viscous reacting hypersonic boundary layer, and shock waves.
Old   November 30, 1999, 04:04
Sanjeev Kumar
Thanks a lot.I have found a book by Chul Park" NONEQUILIBRIUM HYPERSONIC AEROTHERMODYNAMICS". I think it will be helpful for me.
re cfd basics rajesh Main CFD Forum 2 July 16, 2007 13:44
CFD basics... rohan CFX 1 January 25, 2006 02:01
CFD salary dan collen Main CFD Forum 5 August 22, 2001 09:56
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
CFD Symposium (Call for Papers) Chris R. Kleijn Main CFD Forum 0 October 5, 1998 10:25
