December 6, 1999, 12:07 |
Surface Integration
I am needed something about calculation of surface integration using Gause integration method for a panel (like retangular panels) using high accuracy. This could be able to integrate for a given function and local coordinate, the output of intergal could be obtained. If you know some references or separate subroutine, please tell me to find it. Thanks!
December 6, 1999, 12:34 |
Re: Surface Integration
(1). Have you looked into college Calculus or Advanced Calculus books ?
December 6, 1999, 13:25 |
I am looking something as residual coefficients that give accurate value over the surface, not simple one. I have many subroutine to do that, now looking n=200, means the number of w(k)and s(k) by more than 200 coef.
December 6, 1999, 15:18 |
You didn't mention whether the functions are singular or regular! Anyway, there are a number of good integration routines at www.netlib.org
Good luck Adrin Gharakhani |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
