Floating ball on free surface validations
Old   November 10, 2008, 15:57
Default Floating ball on free surface validations
Bak_Flow
Dear Main Forum,
I am working on a case for which I need to do some validation. The case is a transient air-water tank with a ball floating on the surface initially. The geometry is 2-D axi-symmetric, transient and the ball position is solved with a 6 dof solver which really collapses to 1 dof solver due to the symmetries.
The objective of the simulation is to determine the ball position as a function of time for various tank sizes and initial conditions. Initially the ball is floating on water: sg of the ball is about 0.85 but as the tank empties the hydrodynamic forces on the ball pull it below the water level and it seals in the bottom.
Does anybody know of some vaidation work which involves some or all of the physics:
free surface solution in a tank which is draining/presurized and/or floating ball validation in a tank.
Thanks in advance.............Bak_Flow
Thermocapillary free surface flow zakifoam OpenFOAM Running, Solving & CFD 10 December 12, 2016 11:44
Free surface is below than expected..results are not good mechovator CFX 24 April 8, 2011 00:41
Submarine Free Surface samwh CFX 7 August 30, 2009 07:14
sphere in a free surface (thin film)flow Vasu Veerapaneni Main CFD Forum 0 September 15, 1998 17:32
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
