Simulating thermally driven cavity using Compressible equations |
October 4, 2015, 07:28 |
Mihir Makwana
Rep Power: 10 |
Consider a square cavity filled with air ( Pr = 0.71 ) of side L .
B.C : adiabatic on TOP and BOTTOM wall ; Constant temp. of left and right wall ( T_left > Tright ) Mach no. of the flow is approx 1.5e-3 . so, here speed of fluid flow is much slower than that of speed of sound. Thus , Can a solution be obtained by directly solving the continuity, momentum and energy equation. by directly i mean that solving in the following manner http://i.imgur.com/wnv46Po.jpg AND then repeating this process till convergence Please reply. Thanks in advance |
October 4, 2015, 07:44 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
From a mathematical point of view no matter in using the full compressible system. Actually the numerical solution is hill-conditioned as you solve for a condition similar to have dp/d rho -> Inf. The system needs to be pre-conditioned or, much better, reduced to the incompressible form |
October 4, 2015, 07:49 |
#3 | |
Mihir Makwana
Rep Power: 10 |
October 4, 2015, 08:20 |
#4 | |
Rep Power: 71 |
preconditioning is what avoid this problem, for example see: https://www.sharcnet.ca/Software/Flu...g/node1003.htm |
October 6, 2015, 02:59 |
#5 | |
Mihir Makwana
Rep Power: 10 |
Is there a paper you know that solves compressible equations in the manner http://i.imgur.com/wnv46Po.jpg |
October 6, 2015, 09:05 |
#6 | |
Rep Power: 71 |
for the thermal cavity flow, I remember only papers using the incompressible flow modelled with Bousinnesq |
October 6, 2015, 10:50 |
Mihir Makwana
Rep Power: 10 |
ok. fine.
Sir, I have one basic doubt. As the speed of sound is quite high compared to the flow velocity, there will be waves in the system. So, to avoid this , as you mentioned preconditioning can be used. So are we loosing any vital information by applying preconditioning. So, its like we start from state A ( initial condition ) and want to reach to state B ( steady state ) . Both the methods ( i.e directly solving compressible equations AND preconditioning ) will takes us from A to B. but what about the values attained by the variables ( u , p , rho ,T ) in between the states A and B. The intermediate states given by both the methods will be very much different right ? So, are we actually loosing out information by applying preconditioning ? Thus the question is that are we sort of unknowingly throwing away legitimate transience by using preconditioning ? |
October 6, 2015, 11:29 |
Rep Power: 71 |
using a transient model has the same goal both for the fully compressible and incompressible models, any variable subject to the time-dependency must be solved in a way as accurate as possible to give the correct temporal dynamics....It is the chosen model that can disregard some physical information, as the acoustic waves in the incompressible model, the high temperature variation in the Bousinnesq model and so on...
October 9, 2015, 07:16 |
#9 | |
Mihir Makwana
Rep Power: 10 |
Boundary Condition for Driven Cavity problem | dado | Main CFD Forum | 6 | August 15, 2015 20:29 |
Lid driven cavity flow | KK | FLUENT | 1 | December 16, 2009 18:10 |
Traditional driven cavity | Azfarizal b Mukhtar | CFX | 0 | July 27, 2004 21:22 |
Vortex centre in 3-D driven cavity problrms | Apoorva Ghosh | Main CFD Forum | 1 | August 1, 2002 19:22 |
Implementation of inflow/outflow boundaries in a driven cavity | Venakata Prashanth G | Main CFD Forum | 3 | April 12, 2000 02:11 |
