December 1, 2008, 11:23 |
FLUENT VOF for ship's hull
Hi everyone, I'm trying to simulate the flow around ship and I use multiphase flow VOF in FLUENT for analize this type of problem. I use a fully hexa mesh with high qualty ( determinant 3x3 from 0.6 to 1) generated with ICEM CFD
My setting is Reynolds Stress Model, VOF Implicit with open channell formulation, seady state I've tryied a k-w SST viscous model too. I have some problem about this simulation: 1) My simulation diverge with k-w SST, and with the RSM i need to decrease more the under relaxation factor (0.15 max) 2) If i try to simulate a case with y+=50 or less, after 200 iteration the simulation diverge. What can i do?? What type of setting is required?? If someone have any information or solution fot this type of problem please send me at my email : simone.bartesaghi@alice.it Thank's for attention. regards, simone |
December 2, 2008, 04:30 |
Re: FLUENT VOF for ship's hull
Anyone can help me?? Please i'm in very difficulties....
December 2, 2008, 06:24 |
1. Nobody will be able to help you when you give very few details about your problem.
2. People help when they can. You can't hurry them because you have a deadline. 3. You are using CFD on ship problems. Haha! Which idiot talked you into doing that? |
December 2, 2008, 06:53 |
A little harsh, don't you think Bikini Girl?
The guy is desperate and needs help. Plus, he did a reasonable job of explaining his problem, at least enough to get a discussion going. Unfortunately, I do not use Fluent, so I can't help. I'm guessing the Fluent tech support was of no use? |
December 2, 2008, 13:29 |
The most helpful answer I can give you is to underrelax the solution dramatically until it has stabilised. When I say dramatically, I mean that for the segregated solver you would be looking at relaxation factors of 0.05 or so, and for the coupled solver a CFL < 0.2. Some solutions will only work with the coupled solver. If you are desperate, give me some money and I will do it for you
December 6, 2008, 07:45 |
Its seems to be tough in fluent using VOF. I think you may switch over to ANSYS CFX 11.0. Robust solver.
VOF model with planning vessel | vmeertens | FLUENT | 4 | August 9, 2013 16:12 |
about VOF. Fluent or CFD ACE? | Jiyeon | FLUENT | 5 | January 17, 2012 04:37 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Does Fluent Calculate VOF before Momentum ? | Ganapathy | Fluent UDF and Scheme Programming | 1 | April 7, 2010 10:56 |
tutorial on VOF in FLUENT 12 | thinktank | FLUENT | 2 | December 23, 2009 10:21 |
