October 15, 2015, 11:18 |
Stagnation point on the cylinder
Neo
Rep Power: 17 |
Hello all.
I recently calculated unsteady flows around circular cylinder with low Reynolds number of 100. Checking the velocity fields, the stagnation point is oscillated up and down in time within one grid point at the front of the cylinder.(figure is attached) In a broad view, flow fields show the good results in comparison of other numerical papers. Only small oscillation at stagnation point make me bothering. Does it need more care for fixing this oscillation? It would be appreciated with sharing your knowledges or opinions. |
October 15, 2015, 11:24 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
First, the concept of stagnation point in a viscous flow is quite arbitrary, any point on the cylinder has zero fluid velocity... You should define someway in a different way ...however, the streamlines generated automaticaly by tecplot are subject to numerical oscillations, it would be better to see the velocity profiles |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
Calculating the stagnation point of a flow field | Thanitha | Main CFD Forum | 3 | April 2, 2015 17:08 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 11:25 |
The adverse flow before the stagnation point of the blunt body | flyingseed | Main CFD Forum | 3 | April 4, 2013 04:11 |
Stagnation Cp Re=200 for cylinder >1 | Khairy | FLUENT | 0 | February 22, 2007 13:25 |
