December 12, 2008, 07:45 |
udf on parallel fluent
hi, when i run parallel fluent and execute my udf I have no problem but I have no result. this is my udf.. I don't find the problem. DEFINE_ON_DEMAND(asus) {
#if !RP_HOST Domain *d = Get_Domain(1); int ID=18; cell_t c; face_t f; #endif Thread *t=Lookup_Thread(d,ID); /* Thread *tt=Lookup_Thread(d, ID);*/ int i,ntot; #if PARALLEL int pe; #endif real x[ND_ND]; #if !RP_NODE FILE *fp; fp=fopen("temperature.dat","w"); #endif zeta= z0+delta/2.; i=ntot=0; zeta= z0+delta/2.; i=ntot=0; #if RP_NODE do { /*thread_loop_c (t,d) {*/ begin_c_loop_int (c,t) { C_CENTROID(x,c,t); if ((x[2]<(zeta+toll)) && (x[2]>(zeta-toll))) { t = C_T(c,t); u = C_W(c,t); sum_t += C_VOLUME(c,t)*C_R(c,t)*teta*ustar; sum_u += C_VOLUME(c,t)*C_R(c,t)*ustar; } } end_c_loop_int (c,t) tetab[i] =sum_t/sum_u ; zeta +=delta; ntot=i; i++; } while(zeta<zout); #endif } #if !RP_NODE do { fprintf(fp,"%g %g\n",zeta,tetab[i]); zeta +=delta; ntot=i; i++; }while (zeta<zout); fclose(fp); #endif } can you help me? |
Fluent UDF on parallel computing | Andrea | Fluent UDF and Scheme Programming | 22 | August 12, 2015 07:44 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
UDF of Zimont model in fluent | Z | Main CFD Forum | 0 | February 17, 2005 03:07 |
UDF in parallel version. | yobee | FLUENT | 0 | August 17, 2004 04:12 |
pressures in MDM - parallel fluent | paolo | FLUENT | 1 | April 7, 2004 00:38 |
