Meshing trailing edge of aerofoil
Old   December 8, 2008, 05:43
Default Meshing trailing edge of aerofoil
CC
Hey,
when using the boundary layer tool in Gambit to mesh the near wall region of an aerofoil I experience problems at the trailing edge. The x-direction size of the first cell downstream of the trailing edge appears to be equal to the y-direction cell size along the surface. For y+<5, the latter is very small, i.e. 1e-5, which means that the spacing of the cells in the x-direction downstream of the trailing edge is equally small. This, in turn, renders problems at the interface of the boundary layer and the outer region when using an unstructured mesh - the resolution is poor, skew angles etc.
Does anyone know how to change the configuration, so that the x-direction size of the cells downstream of the trailing edge can be increased (and is not equal to the y-direction size of the cells along the aerofoil surface)?
Many thanks for your comments in advance,
CC
Old   December 8, 2008, 20:06
Default Re: Meshing trailing edge of aerofoil
Wifi Lee
I can help you!
Can you send your CAD model to me ?
Old   December 9, 2008, 10:24
CC
Sure - but how do I attach a file?
Email?
Thanks for your help in advance!
Old   December 9, 2008, 17:00
Wifi Lee
Yes,you can send file attached model through Email
Old   December 9, 2008, 17:39
CC
Wifi Lee,
thanks for your reply, but I don't see how I can add an attachement here?
Would you be happy to send me your email address, so that I can send you the file? Alternatively, could you explain how I attach the file using the forum's email?
Cheers,
Claudio
Old   December 10, 2008, 08:57
pc
His bill for providing this service will be in the mail.
Old   December 10, 2008, 09:06
CC
Sorry, but I hadn't been informed that there'd be a bill. In that case, please just leave it alone.
CC
Old   December 10, 2008, 20:22
Wifi Lee
Oh,My dear friends.Simple cases is free.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Y-Plus values at aerofoil leading edge and trailing edge at high incidence Engr07 Main CFD Forum 4 June 29, 2012 10:42
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 12:45
Meshing trailing edge of aerofoil CC FLUENT 1 December 10, 2008 03:49
