Which code to go for free surface wave modeling..
Old   December 11, 2008, 22:12
Default Which code to go for free surface wave modeling..
Ted Chu
I am thinking about getting a cfd software for free surface water wave modeling. I have tried Fluent, but it has only 2nd order upwind numerical scheme for use.
I would like to know other users' opinions regarding STAR-CD's performance on free surface wave modeling (interaction with structure etc.)
Thanks in advance..
Old   December 12, 2008, 03:20
Default Re: Which code to go for free surface wave modelin
John
Star-cd is ok i guess, but you wouldn't want to use it for free surface modeling these days anyway, not with star-ccm+ around. That has got all the comet stuff in so it is really good.
Old   December 12, 2008, 09:17
Ted Chu
Thanks John.. I will explore more about ccm+.
Old   December 13, 2008, 03:13
Charles
Don't write off Fluent. It has a lot of options for modelling free surface waves, and in my experience does an excellent job of it. It is not necessarily easy to do it with Fluent, but the results tend to be very good.
Old   December 13, 2008, 09:44
Ted Chu
Thanks Charles. I am also happy with the performance of Fluent. I am just exploring more options. Actually, the cost for license is also part of my consideration. I have heard that STAR-CD is much cheaper than Fluent. What about CCM+?
Old   December 13, 2008, 10:53
Charles
I've used CCM+ just a little bit. I quite liked it, and locally at least it seems to be less expensive than Fluent.
Old   December 13, 2008, 18:48
Ted Chu
Thanks...
Old   December 29, 2008, 15:42
Shelly Zavoral
An open source code that seems to be gaining momentum is called OpenFoam.
I am not sure if it would do your free surface wave modeling, but, it's free and scales nicely if you are using parallel computing/HPC.
http://www.opencfd.co.uk/openfoam/fe....html#features
Shelly
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Making Wave in free surface flow omidiut CFX 4 August 18, 2011 06:47
Free surface water wave profile John N. FLUENT 0 February 2, 2009 16:17
baffle BC in free surface modeling natesan Siemens 1 September 20, 2005 00:24
Code with reliable free surface capability in a rotating system Subhasish Roy Choudhury Main CFD Forum 1 September 4, 1998 18:47
