How to check size scale effect in a butterfly valve
Old   November 4, 2015, 14:35
fresty is on a distinguished road
I believe yes the next logical step would be to apply compressibility on both water and water vapor..
Though i wouldn't be able to summarize it all but yes this is pretty much doable in ansys and you could browse the forum and conveniently come across many similar/ analogical discussions..
fresty is offline   Reply With Quote
Old   November 4, 2015, 14:56
Hamidreza Bijanyar
bejanyar is on a distinguished road
I tried to find some topic about bubble transfer variable in CFX in forums.
But nothing special i found.
I will continue to search but if you know it i'll be happy if you tell it.
By knowing that i am not even sure that is there something about bubble transfer exist .
bejanyar is offline   Reply With Quote
Old   November 6, 2015, 07:28
Not sure if I could find something precisely for your intended simulation but I could bet on this being doable in CFX.. have you acquired some results using compressibility for your simulation? There are density changes necessary to account for whenever we think of cavitation phenomena per my understanding..
Old   November 6, 2015, 15:28
Hamidreza Bijanyar
If you want the truth , No , I couldn't apply compressibility to my model.
I dont how to do it.
In fluent there is an option for compressibility , but i couldn't find it in CFX.
Old   November 6, 2015, 16:21
You could probably use CEL expression to alter the constant density of the material (create a copy of the material and then in material properties input the density as an expression) as a function of pressure.. something like below which i learnt from CFX forum for a water hammer concept simulation i carried out...
1000 [kg m^-3]/(1-(p-101325[N m^-2])/2150000000[N m^-2])
where 2.15E9 is the bulk modulus fluid elasticity of water..
Old   November 7, 2015, 16:09
Hamidreza Bijanyar
Ok dear fresty.
It worked.
The expression you told for change density by pressure give some error to me.
I replaced "p" with " Pressure" and it worked.
997 [kg m^-3]/(1-(Pressure -101325[N m^-2])/2150000000[N m^-2])
I changed my water to compressible.
In a fixed pressure drop the cavitation in a bigger valve in bigger.
This is acceptable duo to the researches and papers.
But the grow of the cavitation in lower than the value estimated by experience.
I added the compressibility only to water.
Should i add it to water vapor too ???
I attached 3 picture from 12 - 36 - 108 inch valve in fixed pressure drop.
Old   November 8, 2015, 00:23
That's good to know.. yeah the P was just symbolic.. The results seem pretty reasonable..
Regarding lower value, you may have to refine mesh further to get rid of grid induced deviance, apply compressibility to both fluids (which you would need to try as i am not quite sure about it), apply double precision etc...
cheers.
Old   November 8, 2015, 01:38
Hamidreza Bijanyar
Thank you.
In case of adding compressibility to vapor i used similar formula to liquid phase.
By knowing that the density of water vapor is 0.023865 and the Bulk Modulus of water vapor is 3011 .
my ref is this page : http://www.roymech.co.uk/Related/Flu...ter_Props.html
But when you use this values by previous formula the density became negative !!!
assume Pressure = 150000 pa , since 150000-101325 is grater than 3011 result is negative.
What other formula for gas should i use ??
Old   November 8, 2015, 04:01
Not really sure if the same formula could be applied on vapor phase water.. however, as we know from adiabatic conditions and from mathematical as well as physical point of view the density change for a vapor phase should probably simply be the ideal gas relation p2/p1=rho2/rho1..(your example: (200000/101325*0.023865 = 0.04710) this directly indicates increased pressure causing increase in density of the gas...
to reiterate, this is just from top of my head..
[ICEM] Blocking topology for pipe flow with a butterfly valve siw ANSYS Meshing & Geometry 13 November 27, 2012 12:07
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 11:22
Diverging wall scale due to large domain size Kevin CFX 3 November 12, 2006 15:48
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
mesh size and length scale Min-Hua Wang Main CFD Forum 2 November 15, 2001 08:37
