upflow .vs. downflow mixing
Old   December 9, 1999, 02:50
Default upflow .vs. downflow mixing
leejh
hi,
I want to know the flow pattern in mixing vessel
case 1. upflow mixing that is, input is located in bottom and
output is in top
case 2 downflow mixing : opposite case
if retention time in vessel is so fast ( about 1~2min ) and L/D =2.0 then what type( upflow & downflow ) is effective for well mixing ? is there any data about the flow pattern in both case ?
i hope your answer..
Old   December 10, 1999, 04:08
Default Re: upflow .vs. downflow mixing
Jin Wook LEE
Dear Mr. Lee
I think that it depends on many factor such as the location of mixer(stirrer), inlet shape and so on. What I can say is, in general, gravity can not affect the flow pattern. If you have further question, please call me(02-3661-6411)
Sincerely, Jinwook
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
gas-liquid upflow and downflow in packed bed ,the Ergun pressure drop is same? W7032654 FLUENT 0 March 11, 2011 21:26
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
