Multigrid Solver
Old   February 5, 2009, 17:13
Default Multigrid Solver
Nabi
I am trying to solve the incompressible Navier-Stokes equations by multigrid (FAS) using fractional-step method. At the beginning of simulation everything goes fine, but after few hundreds or few thousands time steps, the simulation diverges. I recognized that the divergence is not free on the coarse grids and it makes a kind of instability in the code. Has anybody any idea, how is it possible to have divergence free on the coarse girds? Is it possible to apply constrains for the velocity and/or pressure correction to get free divergence on the corse grid? I thank you in advance.
Old   February 8, 2009, 22:19
Default Re: Multigrid Solver
san
From my knowledge, we should use multigrid method only for solving pressure Poisson equation which is a linear equation in Fractional-step method. Therefore you have to use linear multigrid (correction scheme). If you approaching this method I may help you.
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 08:23
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 11:00
Multigrid with SIMPLE Navier-Stokes Solver tyson Main CFD Forum 1 June 12, 2011 02:09
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 07:45
multigrid solver Raju Main CFD Forum 1 June 27, 2006 10:42
