Nonlinear solver & Differentiation Chain Rule
Old   February 5, 2009, 06:36
Default Nonlinear solver & Differentiation Chain Rule
Frank
I am trying to solve a horrible function using newtons method and need to differentiate it. There is only one unknown variable x.
The problem is that the function I am looking at is a function of a function of a function... very nonlinear and nasty. I don't have access to my elementary textbooks from work and am pretty rusty when it comes to differentiation.
Am I right in thinking that I can repeatedly apply the chain rule, e.g
du/dx = du/da * da/db * db/dx
I'm pretty sure this is right but wanted to make sure before I start sticking coefficients in the software.
Old   February 5, 2009, 07:42
Default Re: Nonlinear solver & Differentiation Chain Rule
Farid
Yes of course!You have to use the chain rule until the expression is easy enough to compute db/dx. If it's a really nasty expression, I would suggest you to do it with Matlab! Otherwise you might make a mistake by solving it by hand.
syms x; (new line) y = nasty espression; (new line) diff(y,x)
That's it Cheers Farid
Old   February 6, 2009, 02:17
Praveen. C
If you have a computer program that is computing these functions, then you can use automatic differentiation. No pain in this. See http://www.autodiff.org
There are AD tools for fortran, C and even matlab.
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 08:23
Could someone suggest simple (nonlinear) solver Bren Main CFD Forum 10 March 7, 2009 06:36
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
Is there any nonlinear solver package at Windows? leaf Main CFD Forum 0 July 10, 2006 23:45
public domain f77 separable nonlinear least squares solver wanted Sergei Chernyshenko Main CFD Forum 10 January 28, 2000 13:56
