How to join domains in Gridgen?
Old   February 23, 2011, 14:00
Default How to join domains in Gridgen?
jack8561 is on a distinguished road
I am working on a 2D mesh in Gridgen. I have 6 domains. Could I join all domains together as one domain? Please help me. Thank you so much!
jack8561 is offline   Reply With Quote
Old   February 24, 2011, 16:52
Chris Sideroff
cnsidero is on a distinguished road
Since those are structured domains, the answer is no. Remember a structured mesh needs a contiguous IJ (K for 3D) mapping. There would be no way to do that with your mesh as is.
If you're using this mesh with an unstructured solver, then it's not necessary to join them. You would simply apply the same volume condition to all 6 domains and the solver would then see it as one mesh.
If you're using this mesh with a structured solver and your solver either doesn't support multi-blocks or you just want reduce the number of domains you need to use a different strategy. Your topology strategy is currently a series of H topology. To be able to use a single mesh for this geometry you would need to switch to a C topology, whereby the mesh would share a connector in the wake. I've attached an image of an example I put together demonstrating what I mean.
It will require a little more work to get it looking nice but once you find the right dimensions and spacings along with a little elliptic smoothing it should be doable. It also might work better if you don't have to use a rectangular farfield box (use a C shape farfield).
Enjoy, Chris
cnsidero is offline   Reply With Quote
How to import NACA 0012 Profile in Gridgen maplepink Main CFD Forum 17 May 7, 2013 13:01
Gridgen - Merging Domains fossu15a Pointwise & Gridgen 1 April 25, 2009 11:06
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
Gridgen problems Vincent Pointwise & Gridgen 1 November 12, 2005 17:20
