December 10, 1999, 20:25 |
Validation of axisymmetric Euler solver
I'm working in a program solver for the compressible Euler equations based in finite volume discretization and a sequential solution algorithm (PRIME compressible). I want to solve internal flows in axisymmetric domains so I need to validate my program with test cases that have this caracteristics. I'm wondering if someone could help me to find this test cases.
December 10, 1999, 23:42 |
Re: Validation of axisymmetric Euler solver
(1). The nozzle flow would be ideal in this case. (2). Converging and diverging nozzle has been used in various method and code development. I don't have any particular reference, but I think you should look in AIAA journal from 60's through early 80's. (3). Or you can do the search in the nozzle flow area.
December 19, 1999, 00:58 |
Just to get things off the ground, a simple Laval nozzle will do fine. You can check Mach numbers, pressures, etc. against area ratio.
If you are interested in more detailed physics like shock capturing or something else then post what those details are. |
December 19, 1999, 18:59 |
a similar question was asked a few days ago (ie test cases to validate euler codes) my answer was to use test cases with exact analytical solutions. you can search the forum under my name to find the message
validation for euler model ( Urgent) | pandaba | FLUENT | 1 | November 1, 2010 06:10 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM | 0 | April 4, 2010 18:06 |
AXISYMMETRIC SWIRL VALIDATION!!! | Maria | Main CFD Forum | 1 | April 11, 2008 07:57 |
Data Structures - 2D FVM Euler Eqn Solver | Scott | Main CFD Forum | 3 | March 31, 2006 06:09 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
