Overpredicted cl and cd on NACA 0012 (with Fluent) |
February 27, 2009, 19:32 |
Hi I am doing a practice of cl&cd prediction using NACA 0012 with Fluent. I have always obtained overprediction on both cl and cd continuously, and run out of ideas on where the problems are. cl exceeds by 20% and cd is over by 70% (at AOA 4, 5 degs)!!
I have run my cases in the following conditions: steady-state M=0.6 (tried 0.2 also) Re = 2M Fully turbulent flow (with S-A model, various viscosity ratio from 0.001 ~ 10 but no help) unstructured mesh, but structured BL mesh y+ on order of unity 2D mesh size 30k ~ 60k points computation domain 100c uniformly in all directions A continuity convergence criterion of 1e-9 cannot be reached, as the residual always hangs around on order of -6 Any comment/suggestion on improving the solution is appreciated! |
February 28, 2009, 01:47 |
Re: Overpredicted cl and cd on NACA 0012 (with Flu
At M_infty=0.6 and AOA=4.5 deg, the flow is highly sensitive to turbulence models. Did you try SST-k-omega?
February 28, 2009, 12:30 |
yes. both S-A and SST models were attempted. Results did not differ much though...
