How to give pressure boundary condition in SIMPLER algorithm
Old   March 16, 2009, 23:40
Default How to give pressure boundary condition in SIMPLER algorithm
Shyamprasad
shyamprasad is on a distinguished road
Hi
I am trying to use pressure boundary condition in SIMPLER code and running to some problems. As per discussion in Versteeg and Malalasekera Book, I gave a specified pressure at the outlet node and CON(Su), AP(Sp) variables are set to 0 and high negative values respectively for the pressure correction equation. Also nodes corresponding nodes are withheld from solving for U momentum.
Somehow this doesnot seem to work. The straightforward test problem I am trying to solve is the following.
For a 2-D flow (like flow between two infinitely long plates) A velocity inlet B.C (left boundary) is being specified. For the outlet(right boundary) Pressure B.C is given. Steady state flow profile and pressure distribution are to be obtained.
For this problem one would expect a parabolic flow profile at the exit but I am getting diminishing velocities at the as I approach the right boundary.
Kindly help me in this regard.
With Thanks
Shyam
shyamprasad is offline   Reply With Quote
boundary, condition, pressure, simpler
Giving pressure boundary conditions in SIMPLER shyamprasad Main CFD Forum 1 March 6, 2009 12:35
how to give boundary condition profile seeta FLUENT 2 October 12, 2006 05:22
Pressure BC in SIMPLER Algorithm? Mori Main CFD Forum 1 August 24, 2006 18:45
SIMPLER boundary condition Ambrose Main CFD Forum 3 November 18, 2002 09:27
SIMPLER boundary condition Ramesh Main CFD Forum 8 November 8, 2002 13:56
