Need a help concerning a pure convection problem
Old   March 14, 2009, 11:14
Default Need a help concerning a pure convection problem
happysmile
Hello all.
I am studying a book entitled 'An Introduction to CFD : FVM approach' by versteeg.
I found two dimensional pure convection problem with discontinuity, and QUICK solver was developed for that problem.
However, my code blowed up in the middle of running. I think source term of the discretized equation is so big which cause the system of the discretized equation to be unstable.
Is there anyone who have an experience to deal with my trouble?
I have a document of the relating equations and numerical descriptions and i can share if leaving e-mail address.
Please reply.
Regards.
Old   March 15, 2009, 19:44
N/A
harishg is on a distinguished road
What was the time marching scheme that was employed ? The explicit schemes have issues with stability. Did you test your code for a simple case like 1-D shock tube problem to check the implementation.
harishg is offline   Reply With Quote
Old   March 15, 2009, 21:26
Neo
9mile is on a distinguished road
My code use space marching called line-by-line method mentioned in chapter 7 of the book. I think the method may be implicit.
What is your opinion applying line-by-line method with QUICK to pure convection problem?
I think my discretized equation applied by QUICK is ok but next step related to line-by-line method is not sure whether is good or bad in this case.
Do you have any suggetions to marching method?
Now, i'm trying to implement relaxation technique but i can not be sure what results i'll get because the author does not mention in the book which marching method he used.
Also i'll consider 1-D shock tube problem.
Thank you for reply!
9mile is offline   Reply With Quote
Old   March 16, 2009, 07:55
Smile scheme
Far
Sijal
which scheme you are using for pressure correction
Old   March 16, 2009, 09:48
Neo
Thank you for reply.
It doesn't need any pressure correction.
The governing equation is as follows.
rho*u*(partial phi)/(partial x) + rho*v*(partial phi)/(partial y) =0
And each of face value for 'phi' in FVM is applied by QUICK method and for multi-dimension, line-by-line method is used.
That's all.
Old   March 17, 2009, 05:12
jugghead is on a distinguished road
If it has discontinuities you can use CICSAM scheme.
jugghead is offline   Reply With Quote
Old   July 8, 2009, 13:24
Nishant Kumar
Nishu is on a distinguished road
Can someone send me the 1D code for shock tube problem at babuu.nishu@gmail.com? I need it for my research.
Thanks alot
Nishant
Nishu is offline   Reply With Quote
Very simple natural convection problem Naseem FLUENT 19 December 17, 2020 16:00
Flow is not converging in natural convection problem of boussinesq model for air rahulsharma FLUENT 4 December 2, 2020 21:07
Natural Convection Problem - Helium marzoa STAR-CCM+ 0 April 18, 2011 14:12
Convection & conduction simulation problem debashis FLUENT 1 June 26, 2009 03:45
Natural Convection Problem Eduardo FLUENT 0 October 21, 2006 14:04
