November 27, 2003, 10:50 |
Implementation of Germano-Lilly model in LES
Hello everyone,
I am currently attempting to implement the Germano-Lilly subgrid model into a LES code, but I am having some difficulties. The code will be used for studying boundary layers and free shear layers. Initially, I have set the code to calculate Lij, and this is done by test-filtering the veolcity components (and the products), in the manner of the reference the reference (http://www.tfd.chalmers.se/doct/comp..._files/les.pdf). Now, the values of Lij behave as expected - tending to zero near the wall and constant in the free-stream. My code then calculates the test filtered Sij term (S^ij), and this is where my problems begin. I am unclear as to the whether the dx in the equation S^ij = 1/2 (du^i/dxj + du^j/dxi) corresponds to the test-filter width or to that of the grid spacing. Also, after I have test-filtered the |S|Sij term, I find that I need to set a boundary conditions for this term to close the system on my computational domain. Is there a simple way to do this, or have I made a bad assumption in how my test-filtering works? |
January 20, 2016, 18:32 |
More than 10 years after this post, but I was wondering if you still have time to discuss about your achievements? I am coding my Dynamic procedure and it has been very difficult to implement some sections
Display Modes | |
OpenFOAM: LES turbulence model names | Ollie | OpenFOAM | 5 | January 7, 2013 11:24 |
UDF for linear PTT model implementation | dpitz | Fluent UDF and Scheme Programming | 1 | February 4, 2011 11:08 |
Regarding Implementation of Hershel Bulkley Model in Viscosity correlation | Pathak | FLOW-3D | 0 | August 24, 2009 07:34 |
Bug in Dynamic 1Eq Eddy Viscosity LES Model Incompressible flow | harishg | OpenFOAM Bugs | 5 | December 2, 2008 19:18 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 06:24 |
