February 5, 2016, 09:21 |
shock tube exact solution
Ardalan
Rep Power: 16 |
I need the exact solution of 1d shock tube problem after the waves are reflected from the walls. Existing codes and solutions are about the case that region are infinite (for example sod shock tube).
February 5, 2016, 14:17 |
Rep Power: 16 |
What you can do if you have an exact riemann solver in hand is to split the problem in two parts. You first get your solution before waves reach the wall then you take your star states and reinject them into a second exact riemann solver run. For example in the Sod shock tube you have a shock traveling to the right. Take the right star state (e.g. the state between the contact and the shock) then build new initial states for the second run. Your second run will have as initial left state the above right star state, and initial right state the same right star state with inverse velocity (this is your wall). This second configuration will give you a double shock problem where the solution you are looking for will be located between the left traveling shock and the contact. This gives you the solution for your reflected shock. Good luck ! |
Shock tube simulation in Fluent | Vinoo_P | FLUENT | 28 | September 6, 2018 00:21 |
analytical solution of 1D shock tube problem | ma | Main CFD Forum | 10 | May 11, 2015 05:20 |
1D solution of shock tube | immortality | System Analysis | 8 | June 27, 2013 12:25 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
shock tube validation | AB | Main CFD Forum | 3 | December 10, 2004 07:31 |
