December 21, 1999, 05:08 |
Phoenics
Hi, I'm a student working on his engineering thesis. Is there anyone who can help me expecially in two or three things concerning the CFD code "PHOENICS" ? Thank you in advance.
December 26, 1999, 08:35 |
Re: Phoenics
what kind of help do you want? I had my thesis in 3-d flow over a surface mountainted building and I used phoenics
January 6, 2000, 05:50 |
Re: Phoenics
I'm working on my thesis about fires in road tunnels and I would like to know: 1) How do you "model" a body-force working on a fluid. 2) How do you read, in the result file, the nett sources of momentum 3) Do you know any particular rule, in PHOENICS, about the aspect ratio of the cells.
Thank you, and wish you a great year. Gabriel |
January 25, 2000, 08:12 |
Re: Phoenics
as[ect ratio is not as important as rate of expasion of cell size. I've run models with cells that had spect ratios of 20, but there were not a lot of them.
Need help about phoenics | mukut | Phoenics | 5 | April 14, 2010 03:29 |
ICEM CFD (Hexa) - > Phoenics | James Date | Phoenics | 2 | September 2, 2004 15:18 |
Colors & DXF format in Phoenics. HELP | Yiannis | Phoenics | 3 | November 12, 2001 13:00 |
PHOENICS code IV | mehdi | Main CFD Forum | 3 | July 7, 2000 18:49 |
Use of an hydrodynamic model integrated in the vertical by the PHOENICS code | Hafsia Zouhaier | Main CFD Forum | 2 | March 15, 1999 08:23 |
