February 23, 2016, 09:07 |
closed pipe decompression
Ardalan
Rep Power: 16 |
Consider a pipe filled with compressed air (1.5 atm). Both ends of the pipe are closed. At the time=0 right end is opened and is exposed to atmospheric pressure. consider the flow to be one dimensional and the governing equations to be Euler equations.
1- What are the appropriate boundary conditions at both ends (opened and closed)? 2- Is there a reference solution for this problem in the literature? 3- is it possible that the pressure inside the pipe falls below the atmosphere? |
February 23, 2016, 09:25 |
Filippo Maria Denaro
Rep Power: 71 |
I think you can get many details from the classical Riemann problem in a textbook of gasdynamic. Your problem will generate three characteristic waves
February 23, 2016, 09:46 |
Ardalan
Rep Power: 16 |
Existing Riemann solutions in the gasdynamics textbooks are only about shock tube problems with both ends closed. A diaphragm somewhere inside the pipe ruptures and the flow begins. I can simulate this flow perfectly. But I get in trouble with the one end opened pipes (as mentioned above)
February 23, 2016, 11:03 |
Rep Power: 71 |
February 23, 2016, 12:31 |
Ardalan
Rep Power: 16 |
February 23, 2016, 12:53 |
#6 | |
Rep Power: 71 |
Actually, the classical solution in a shock tube is for an infinite lenght of the tube, not for a closed one ... As you want a 1D approximation the exit from the pipe in the ambient that would generate oblique waves is not considered and I think you can afford the model as a unique 1D model with 2 Riemann problems. Of course, after waves touch each other in the pipe you must consider reflection. |
February 23, 2016, 17:28 |
Ardalan
Rep Power: 16 |
Thanks for your response.
But I didn't get any answer to my questions: 1- What are the appropriate boundary conditions at both ends (opened and closed)? 2- Is there a reference solution for this problem in the literature? 3- is it possible that the pressure inside the pipe falls below the atmosphere? |
February 28, 2016, 03:04 |
Ardalan
Rep Power: 16 |
Any help is greatly appreciated
[DesignModeler] DesignModeler Pipe within pipe | shields | ANSYS Meshing & Geometry | 13 | November 25, 2018 22:14 |
Double Walled Pipe Boundary | dahvqaz | FLUENT | 2 | December 5, 2012 10:14 |
Closed loop pipe flow | maddalena | OpenFOAM Running, Solving & CFD | 34 | August 16, 2011 11:46 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
