The Effect of impeller type on flow pattern
Old   January 20, 2000, 22:22
Default The Effect of impeller type on flow pattern
lee ji hyun
HI!
we want to know the effect of impeller type on the flow pattern of the vessel
The impeller type we want to know it like this
Flat paddle type : Flat turbine type (radial flow type)
Is there any site to see the flow pattern using various type of impeller ??
thank you for considerations.
Old   January 26, 2000, 08:35
Default Re: The Effect of impeller type on flow pattern
Francisco Saldarriaga
Yes it matters in a vessel with differetn patterns.
Look at www.ametek.com. They manufacture impellers,...etc.
Good luck.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 07:32
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
