Channel with 2D surface mounted obstacle
Old   December 21, 1999, 10:06
Default Channel with 2D surface mounted obstacle
Francesco Marra
Dear all,
I am looking for (DNS/LES) simulations or experimental measurements of turbulent channel flow with a 2D surface mounted obstacle having rectangular section. I am interested in obstacle with height up to half of the channel height and Reynolds_bulk less than 8000/10000. Of course I am speaking of published references but any kind of indication will be gratefully appreciated.
Thank you in advance.
Francesco
Old   January 5, 2000, 03:49
Default Re: Channel with 2D surface mounted obstacle
Jonas Bredberg
There are a magnitude of published results for experiment and quite a few predictions with turbulence models, feel free to contact me if you need any advice or additional references. The DNS and LES are however very few, below are something that might be helpful, although not entirely what you are looking for:
author = "M. Ciofalo and M. W. Collins",
title = "Large-eddy simulation of turbulent flow and heat transfer
in a plane and rib-roughened channel",
journal = "Int. J. for Numerical methods in Fluids",
volume = 15,
pages = "453-489",
year = 1992
Re=26600
author = "D. Laurence and S. Parneix and P. Durbin",
title = "Second Momentum Closure of a DNS Backstep Flow Database",
booktitle = "2nd Int. Symposium on Turbulence, Heat and Mass Transfer",
year = 1997
with reference to the DNS-data of Le, Moin and Kim
Re=5100
author = "A. Murata and S. Mochizuki",
title = "Large Eddy Simulation Applied to Internal Forced-Convection Cooling of Gas-Turbine Blades",
booktitle = "11th IHTC",
pages = "565-570",
year = 1998
Re=4200
You should of course also check surface-mounted cube simulations, although not in my area I could send you a copy of one of my colleagues (S. Krajnovic) forthcoming thesis (in a couple of weeks) treating LES of such flows.
Best Regards
Jonas
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
Can Flow-3D plot the free surface area in Iso-surface or colour variable? therockyy FLOW-3D 1 June 20, 2010 19:36
BC for free surface in straightopen channel flow moon1234 FLUENT 0 March 15, 2010 06:50
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
