Edge not aligning properly
3 Attachment(s)
I'm facing a minor problem in edge alignment. The vertices are connected and it supposed to be straight but when i give projected mesh option. I can see some bend in the edge where connecting to the vertices. Please see pics. I tried edit edges option and checked vertices positions both are in same height only. The bad elements are occuring due to this problem. In other side of the geometry, there is no bending edges like this. Please help me to fix this issue. Attachment 47135 Attachment 47136 Attachment 47137 |
2 Attachment(s)
Hey,
I'm facing a similar problem. I'm trying to mesh a sinusoidal profile. I'm attaching 2 pics. In the first pic I've associated the edge to the curve and in the second pic, I've not associated the edge to the curve. In the first case, you can see that the mesh lines are not vertical. In the second case they are. I've associated everything properly. I'd meshed a similar geometry previously and everything seemed fine. I don't know what's happening in this case. Any help is greatly appreciated! Attachment 47149 Attachment 47150 Thanks!! Ram |
Please let me know when you find solutions for this.
