July 5, 2016, 06:54 |
8 node quadrangles mesh with GMSH
Tshering Lhamo
Rep Power: 9 |
Hello, I have a file from the Lagamine with nodes and elements. Elements are 8 node quads. I converted the file to mesh format with Matlab. When I open it with gMSh, it says Vertex Index error.
I was wondering what could be wrong? Thank you |
July 5, 2016, 09:25 |
Jonas T. Holdeman, Jr.
Rep Power: 18 |
Don't know the requirements for gMsh, but Matlab uses indices from 1 to n for n items, while applications based on C-language often run from 0 to n-1. This can generate indexing errors.
July 5, 2016, 11:25 |
Tshering Lhamo
Rep Power: 9 |
Thank you... finally managed to find the error.
2d mesh, 8-node quadrangles, gmsh |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Gmsh] failed 1 mesh checks (gmsh) | appa | OpenFOAM Meshing & Mesh Conversion | 2 | July 30, 2015 17:09 |
Gmsh vs. Pointwise mesh. | paka | Mesh Generation & Pre-Processing | 1 | June 13, 2015 00:53 |
