May 25, 2016, 11:34 |
Questions on Navier Stokes Eq
dd
Rep Power: 9 |
Hi, i have some questions on N-S Equations on 2D Lid Driven Cavity.
Edited Question: Re = UL / v (U=velocity of lid, L=length of lid, v=kinematic viscosity) As far I know, I have to vary the Reynolds number to get different results. but which of the variable on the RHS I have to change? For example, I want to get the results on Re=100 and Re=200, so do i change the L/V/v? Last edited by calmbeep; June 1, 2016 at 09:32. |
May 25, 2016, 11:44 |
Filippo Maria Denaro
Rep Power: 71 |
I suggest to study better the basics of fluid dynamic before go into the CFD study... It exists only one system of equations, they can be made non-dimensional but the solution obeys the same system and the mathematical character of the PDE is the same.
The discretization is the same for dimensional or non-dimensional form. |
May 25, 2016, 21:26 |
#3 | |
LUQILIN
Rep Power: 9 |
Test book 1. Computational Fluid Mechanics and Heat Transfer, Richard H.P. , Chapter 9 Section 3. Test book 2. Computational Fluid Dynamics - The Basics with Applications. John D. Anderson., Chapter 2. |
May 26, 2016, 07:05 |
david
Rep Power: 13 |
The discritization does not matter. Your boundary inputs does. by normalizing the navier stokes, your solver now becomes "Reynolds-number dependent". your velocity at the inlet is normally 1. For example, if you are doing a flow over an airfoil and the Reynolds number is 500 (based on chord and freestream velocity), the right hand side of the eqn( the viscous term) is now divided by 500. This suggests that you need to have an option for the user to input the desired Reynolds number. Again velocity at the inlet is unity.
May 26, 2016, 13:07 |
dd
Rep Power: 9 |
okay thanks DENARO and Luqilin for the heads up. I will look on the textbook first.
david : ah i see. thank u for the help edited: so u mean Re=vL/(viscousity). For the coding, which variable am i changing? As in if I am varying Reynolds number, which terms on RHS I should be changing? Last edited by calmbeep; May 26, 2016 at 16:16. |
Filtered navier stokes equation..LES:: | Palani Velladurai | Main CFD Forum | 7 | September 6, 2013 02:51 |
Newbie Navier Stokes Questions + Grid | Jigar | Main CFD Forum | 4 | February 6, 2006 12:14 |
Navier stokes compresible viscid flow fea, somebody can help? | Jose Choy | Main CFD Forum | 3 | October 24, 2003 02:28 |
Newbie:Viscoelasticity and Navier stokes equation | Rajil Saraswat | Main CFD Forum | 2 | June 9, 2003 07:21 |
help: I am trying to solve Navier Stokes compressible and viscid flow | Jose Choy | Main CFD Forum | 2 | May 18, 2000 05:45 |
