May 26, 2016, 12:48 |
The Best equation.
Kamilva
Rep Power: 9 |
Can anyone suggest the best solver equation for solving CFD simulation for Centrifugal pump. This case is highly turbulent and rotating one. |
May 26, 2016, 22:39 |
Lane Carasik
Rep Power: 14 |
May 27, 2016, 01:19 |
Kamilva
Rep Power: 9 |
And thanks.... I just want to know whether I should use k-epsilon or k-omega... To get fine results. |
May 27, 2016, 03:43 |
not_real_name
as far as I know, the k-epsilon model is good for small pressure differentials. The other one I think will suit you better as it is widely used to simulate turbulent flows. |
May 27, 2016, 05:39 |
Jiri
Rep Power: 13 |
Navier Stokes equation for compressible flow including cavitation is the best equation. Try it :-).
June 6, 2016, 01:39 |
Millen
Rep Power: 10 |
K Omega SST is probably best for this situation as your needing to accurately capture currents around the blades. Also, make sure you make use of the inbuilt wall functions of SST if you do use it by having a good enough inflation layer around your walls and blades.
rotational and inviscid | Mike | Main CFD Forum | 40 | November 9, 2023 06:03 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Some problem of "Qcriterion.mcr& | yuyuxuan | Tecplot | 9 | February 12, 2016 03:27 |
Need help:about energy equation in CFX | Stein | CFX | 4 | July 2, 2009 22:31 |
Boundary conditions in a Poisson's equation? | vincent | Main CFD Forum | 4 | April 16, 1999 02:19 |
